gejurkovich
New User
case 220 not charging. has stator charging system.
Checked stator leads to ground, no continuity.
Checked stator leads to each other. yes continuity.
Checked voltage between leads while running. Had zero, but was fooling around looking for something out of place and temporarily had about 30 volts ac from the stator, before I could plug it into the rectifier, voltage went back to zero.
Bad stator ? loose/bad connection at the stator ? Or ?
Thanks for any suggestions
