Cub Cadet 125 Mower PTO clutch parts
Roy Suomi
I can't seem to find a P/N 759-3490 pressure spring for a 125 Cadet with manual PTO clutch on the engine. This spring is triangle
shaped and has a hole in the center. I've got 2 used springs from engines here, but none worth a hoot. None of the kits available on
Ebay have all the parts needed to rebuild this clutch. I Save Tractors didn't list it. I didn't want to buy 2 kits [ $180.00] to get
all the parts needed. Apparently it's not available thru Cub Cadet. I looked on Amazon too. Somebody has to sell this spring plate
separately.
Yep, I highly recommend Cub Cadet Specialties, the LARGEST VOLUME CUB CADET PARTS DEALER in the USA. If Charlie can't get it from Cub Cadet he finds the actual maker of the part or has a new supplier make it.
I have had some luck reshaping (bending) the spring if it isn't damaged too bad. The posts for Ray and Charlie will have what you need if reshaping does not work
