My Cub 125 has been sitting for a about 8 months. Went to start it and the battery was dead. Swapped another battery in and it seemed to be drawing a current. Turned the key and the cub fired up and was running. After about 30 seconds I noticed a light down low - leaned to the right and could see a fire down low. It kept burning and getting bigger. One of the headlights came on... Turned it off and unhooked the battery connections. Poured some water on the fire and put it out.
The main wiring harness appears to run down the right side of the frame and hooks up to the starter generator and the fire appeared to be right where the loom turns up and runs up the side of the grill to the voltage regulator and headlights.
I just want to put this thing together and sell it. How many wires are inside the loom?
