This Craftsman push mower with 6 horse Honda has been trouble free and started on first pull for more than 15 years. First of year wouldn't offer to start without a squirt of carb cleaner then bust right off,run few seconds and die. Tore carb down and inside looked exactly like lead battery cable end with leaky case around post. No use in going any farther so I began searching for a new carb without any luck. I wouldn't have put 10 cents against your dollar bill the carb could be cleaned out then work but finally decided to try anyhow. After I washed away corrosion the housing was badly pitted like a cable end on it's last leg. Had you saw the condition I'm sure you would say no way but unbelievably it started on the first pull. Why you might ask would I have cussed under my breath when it came alive and ran like it had all those years? I was pi$$ed to think of pulling on 2 or 3 year old mowers in the pasted until my arm hurt. This carb is very simple and no means of adjustment so I don't understand why every mower doesn't use one like it. Here's my question. What if anything would you do in attempt to prevent corrosion returning? I have a cut off between tank and carb but wonder if sitting dry might make it more prone to corrode. For the last 10 years or so I've ran Seafoam in gas comming up on time engines will be used less often. I've never heard mention of metal corrosion caused by Seafoam but I can't help but wonder.
