the tractor vet
YUP got problems with the carb. I thought i had it solved buy NO , it is leaking gas past the needle and seat . Then i discovered that the throttle shaft is a bit floopy . A friend had a carb that has a tight throttle shaft but it has been setting for a vary long time . I got into it today and had a problem getting out the main jet to the point that we had to add HEAT and LOTS of it along with my good Panther Pee and a ezze out , needles to say the main jet and discharge is toast . Anybody have a lead on a replacement ??? i really don't want one of them CHINA made lookalikes . ea if i have to i can have one made , i just hate begging the one guy that could make one to do it . I don't have enough Crown Royal to drown out his WHINNING.
