Fordson Major Diesel Hydraulic Gaskets
I am going through the hydraulic system on this Fordson and replacing all the orings. The 3pt lift would drop once in the raised position. I have the oring set from yesterdays tractor but I'm now trying to find the gaskets. This tractor has some type of remotes it seems. Here is the picture of the gasket surface in question.
They were not a very common unit so i suspect you will have to get some thin gasket paper and a little ball ended hammer and make your own. Would not advise instant gasket as excess may get into the hydraulic valves.
