I need help to indentify this Fordson 4 cyl.diesel head and simms pump. I acquired this engine from a co-worker who needed to free up some space in his garage. This engine powered a air compressor for jack hammmers. He has had it since 1960. He had the block rebuilt (new pistons and sleeves) and replaced 6 valves with new ones. Problem was during reassembly he accidently cut the head gasket between the cylinders 1 and 2 and did not properly torque the head bolts. Four middle bolts where loose when i disassembled the head. Now the bad news.....My barn was broken into last week and among other scrape metal i had in there they also took the Fordson block which was convienently attached to the original trailor. My barn is 1/8 mile from my house with no electric to it with to many field intrances to the barn. Here are some casting numbers if you all can help with indentifying the model Fordson this was and the year and horse power.....Regards....Tom.... I tried to post pictures but the site says i've been inactive to long...sorry , could'nt afford the internet any longer then..
Head cast numbers>>E1ADDN6050 or 6D5D with a C or a G at the end hard to read....
Simms injector is SPE4A75S 647
