Fordson Tractors Discussion Forum
Re: Hole tapped in side plate of injection pump PM
Bob
09-09-2004 20:59:45
I'm not up on all the possible variations, but some of the pumps use engine oil in the pump "cambox".
If yours is, indeed this style, it should have engine oil in it, and it should be changed AT LEAST as often as the engine crankcase oil, because there is some internal leakage of diesel fuel in the pump, which thins the oil.
Hopefully, an "expert" will come on here to clear this up for certain!
Here's a related post.
Miles
09-10-2004 19:39:12
 Re: Hole tapped in side plate of injection pump PM in reply to Bob, 09-09-2004 20:59:45
This the late version of pneumatic type with 8 bolts on cover. The tapped hole was definately added after the fact... Maybe to bleed air from fuel.
ron algiere
09-13-2004 18:07:50
 Re: Hole tapped in side plate of injection pump PM in reply to Miles, 09-10-2004 19:39:12
I have a 59 power major and have been told not to fill the pump box with oil, it lubricates itself with fuel and blows out the excess thru the pigtail vent at the bottom. If you fill it with oil it will just run out of that vent!
Mark S.
09-16-2004 20:44:59
 Re: Hole tapped in side plate of injection pump PM in reply to ron algiere, 09-13-2004 18:07:50
Would it be safe to say the added motor oil would not hurt anything?I usually add oil to it in the spring when it has been sitting a few months.Only one of my five pumps has the filler plug, so it is not a factory item for sure.I would say if it is noisey then chances are it needs to be rebuilt.I hope this helps.
Julian H
09-22-2004 19:26:49
 Re: Hole tapped in side plate of injection pump PM in reply to Mark S., 09-16-2004 20:44:59
I've been driving the same '59 Fordson Power Major since the '60's and never put engine oil in the injector pump the first time- same pump, no problems.
MarkS
09-26-2004 09:13:31
 Re: Hole tapped in side plate of injection pump PM in reply to Julian H, 09-22-2004 19:26:49
That is good to know.2 of the 4 pumps that I own have rebuild stampings on them.There has to be some explanation for the bearings giving out.My 1961 was not run for seven years before I used it, so I was told.The pump seems fine after four years of service but it also has a rebuild stamping on it.The 1958 has sat for five years and should see service soon.I will use the extra two pumps that have not been tested to see what they do and post it here.
