Hydraulic Line 1974 Ford 3000
oneofeach
My hydraulic suction line, the larger of the 2, needs to be removed from the rear end. I am wondering how the pipe goes into
the elbow and then the elbow into the housing. I am thinking o-ring pressure fit on each but not sure. It's just below the
pressure line near brake pedal pivot shaft. All thoughts appreciated
Yes, it is a simple slip fit into an Oring.
Loosen the clamps that hold it to the chassis and I think? remove the foot board.
Then grab it with both hands and pull straight out on the pipe. Same on the other end too.
When I reassdmble one of those I always wash the fitting out with a rag dipped in lacquer thinner then apply a tiny amount of silicone around the tube. Even a small suction leak there will have you pulling your hair out when you try to bleed the pump.
