Company Logo (800) 853-2651 Shop Now
555c harmonic balancer timming
mic-t
01-27-2023 05:19:38
Can anyone tell me how to time the crankshaft balancer with the crankshaft .I have put new gears in the balancer and I cant see the marks on the crankshaft . with the counter weights down and #2 at TDC is that where its supposed to be timed at or am I misunderstanding the prosses .
mic-t
01-27-2023 08:26:35
 Re: 555c harmonic balancer timming in reply to mic-t, 01-27-2023 05:19:38
I did find a mark on the crank but its just a v-mark on the crank not on the gear like the pic shows
Bern
01-27-2023 16:37:08
 Re: 555c harmonic balancer timming in reply to mic-t, 01-27-2023 08:26:35
You're looking for marks on both the crank as well as the balancer gears. If you can't find one on the balancer gear, make sure you don't have them installed backwards or side to side.
V-mark or slash mark, doesn't matter. Make sure #2 piston is at TDC and that balancer weights are parallel to the block.
Bern
01-27-2023 07:41:23
Take a closer look. There should be a mark of some sort on the crankshaft. If not, make sure the crank is at exact #2 TDC and the weights are parallel with the block surface when the marks on the weights are where they should be. That should be close enough. Third Party Image
