I have searched this topic and almost all responses cease short of resolution. The long and the short of this situation is that I have replaced the wiring harness, voltage regulator, instrument cluster, battery, and generator. The aggravating thing is that generator light stays on all the time. It dims a little at higher rpm but never goes out. I've tested the gen output and it is strong. I've polarized the gen and voltage reg. The generator mounts were sanded to bare metal. The battery ground is bare metal. The oil light works fine as does the temp gauge. The transmission light works normally as do the headlights. The only gauge that is squirrely is the gas gauge. It bounces all over the place and reads empty sometimes. I have grounded that particular wire and it pegs to full. So the gauge at least seems fine. Don't know about the sender unit. Does the fuel sender have a dedicated ground or is the diesel tank the ground? I can push the contacts closed on the voltage regulator and the light goes out. I'm sorta at my wits end so any input would be greatly appreciated.l
