Hello all, I'm losing my mind!
Short story. 1 month ago started tractor and it ran fine, but tire on the trailer that the tractor was on had a flat. Repaired the tire went back 2 weeks ago and put tire on and got ready to go to the farm. Tractor would not start. Getting fuel to the sediment bowl, getting fuel to the carb, not getting fuel to the plugs. I transported the tractor to my house to rebuild carb. Rebuilt the carb put it on AND..... The tractor is stuck in 3rd gear. I put the tractor in gear before transporting it home (40 miles). Went into gear easily before bringing it home. Clutch pedal moves, shifter does not budge. If I try to crank it the starter tries to move the tractor forward. I would try to crank the tractor off the trailer, but I have a bushhog on it and the trailing tire of the hog is hanging over the front rail of the trailer.
I does not make sense Transmission worked fine one day and again a week later, then after a 40 mile ride it is locked up. Is transporting in gear a no no? That is how my dad always did it before I inherited it.
I got to get it out of gear to try to start it, I can't lift the bush hog without it running, can't get it off the trailer without the bushhog up.
How do I get it out of gear???????
ANY HELP is Appreciated. I'll try to attach a few pictures
