The fitting on my SOS shifter where the shift cable connects has disintegrated. Would anyone know where I could get a replacement or maybe the whole shifter at a reasonable price? This all started when the SOS shift handle lost all tension. It seems the upper and lower cable became disconnected from each other. I took the transmission cover off and it has been a bonefied b%*#H to get the cables reconnected (PTO and SOS) I mean, good Lord, could they have made it any harder to get those hard cables connected to their respected locations?
Also, if anyone could tell me or show me what "Park" looks like in regards to the control valve assembly I would be extremely grateful. I have read that the control valve automatically goes to park when the engine is off which means all 6 valve spools are in the "Out" Position. Can you manually turn the shaft with a screwdriver all the way to one end or the other and be get the valve in the "Park" or "Out position? When all the valve arms were evenly lined up and the "buttons" (for lack of a better word) are all "out", I don"t think it is in Park because the shaft can still be moved into other detents. It would seem that "Park" would be all the way to one direction.
Thanks again for any help.
I think I may have purchased a doozy of a first tractor. The more I read the more I wish I had gotten a manual transmission.
