1955 FORD 860 Lift Cylinder
777777
New User
Bad seals in the lift cylinder for the bucket on the cap end, it looks like a union with an inlet valve for a hose, need to replace the seals. can anyone give me a link to a site that will have the whole kit, cant seem to find it.
thanks
you post is mighty confusing. you posted similarly the other day and I asked for more info... none came...
1, you are looking up N parts and you state you have a 860.. the lift piston and cyl are not compatible by any means.
2, it almost sounds like you are talking about a loader since you mention a 'bucket'
how about you disambiguate your statement a lil??
soundguy
By the circled area on your photo I think you want the packing seal assembly. That would be item #4 Packing Assy. 86529795 available from your local or favorite online New Holland dealer.
The NH seal kit is over $60 and came with only two vee rings. All of the ones I have taken apart had three vee rings in them. I now get my seals from Baum hydraulics,they don't have a kit for the one arm loader but you can get all the seals individually. Size 2-1/2x3x1/4 vee rings.
Is it possible that you are describing an hydraulic hose fitting with a swivel incorporated into it? If it is you should be able to take it off and take it to any hydraulic shop.
thanks john, thats exactly what i'm looking for, great schematic, i appreciate it alot
777777
