18.4 X 30 Duals
Brian Allen
All is well in the universe!
I found a good set of T bar duals near here, "and" the seller is throwing in a pair of 50% 18.4 X 30 tires on rims too.
The price - $600.00 CDN
These are from an 1840 J D with front assist.
I'll have to dig my gooseneck trailer out of the snowbank to pick them up.
Brian
Nice find! Are the 'spare' 18.4's going on your
4600, or are the duals 16.9's? (Your 4600 has
16.9's right - or do I have your 4600 and BrianMA's
mixed up again?) You also won't believe how much mud
it will go through with duals and a bale on the 3-
point!
Yep, and then you'd need a tow truck to retrieve you...
When you get stuck with a dual'ed tractor, you're really stuck.
I got to check them out today.
Some weather checking but very usable set in great shape otherwise.
The spare set of 18.4 X 30s has JD rims that could be made into another set.
HHMMMM tripples!!!!!!
The "T" bar setup is in very good shape but I'll have to find the correct size eyelets for the set.
Now I have to get that tractor repaired now so I can admire the setup.
I'll get pictures when I'm done.
Brian
