I was wondering if anyone had first hand experience with putting a 134 head on a 172 engine and what the power gain might be...
Also, will the head gasket (and other engine parts) be able to handle the higher compression ratio?
Last, I assume these are direct bolt ins with no modification required, however, how do the valves compare in the two heads? Seems to me higher compression ratio is moot if the valves are smaller.
Thanks.
Thanks.
