Figured I may as well try and isolate the problem with the fuel gauge on my tractor.
I wired from voltage stabilizer to gauge. From gauge to sending unit. From other post of sending unit to ground.
I switch on the circuit and the gauge does not move. At all.
Tank is not empty .... and not full.
I reverse the wires on the sending unit. As soon as I switch on the circuit the gauge moves from empty to full. Turn off the circuit and it slowly moves back toward empty.
I remove the ground wire from the sending unit, leaving the wire coming from the gauge on the sending unit ..... switch on the circuit and the gauge again moves to full.
I switch the wire at the sending unit back to the other terminal .... switch on the circuit and nothing.
Bad sending unit??
Bad sending unit??
