I have a 1956 640 that is giving me fits. It ran last week and has been in the barn and has not sat out in the rain. It cranks over but no fire. The tractor was restored last July.
Here is what I have done so far. Battery voltage at the battery 6.4 volts, at the coil 5.6 replaced the switch. Battery voltage at coil now 6.4 new cap, new rotor, new points, new condenser, new plugs new coil and new wires. Points set at .024 distributor shaft does not appear to be loose or have any wiggle to the shaft. The distributor is original but this tractor has run great up till now. I mowed 10 acres with it last week and it ran great.
Is it common for a distributor to go bad in these tractors? I have not had much time with Ford tractors.
Any help?
Any help?
