1953 Ford Jubilee muffler clamp
grmeyers
New User
I am looking for the original muffler clamp that fits the inlet (right) side, I can find the outlet side but not the inlet. New Holland said they no longer supply it. Any suggestions please.
I have several original muffler/exhaust pipe clamps. What is the OD of your inlet pipe?
I will need to measure it when the next time I am over where the tractor is. I think it is less than 2" but need to check, will get back. Was hoping some one would know.
There were 2 different size mufflers used on the NAA/Hundred/HundredOne series tractors. Your NAA originally had the small one but if the manifold has been replaced there is a chance that it now has the larger muffler on it. Measure it and I'll see if I have your clamp.
It defiantly has the larger one on the intake side. Without measuring it, I think the outlet size is like 1 3/4 but the intake side is larger. Some where on the net I have seen the dimensions but can't seem to find it. I will need to pull the muffler off and measure it when I get over where it is next week. It looks like this one.
http://www.external_link/detail_redirect.aspx?ID=1080&mybuyscid=9761816418
