NWMO 901 SOS
Good afternoon all,
I have been messing around every so often trying to find the right combination for mounting the new alternator. I ended up rotating the bottom support 180 degrees and shimming it out about 1-1/2". This allows me to mount the alternator in front of the bottom bracket with a bolt that runs full length (roughly 8 1/2"). By shimming out the bottom, i was able to use the top bracket unmolested, save a few shims to move it forward a little. This also allowed me to use the old 41" belt. I did not swap pulleys as the genny pulley would have moved me further forward than I could allow and I left the 3/8" pulley with the 1/2" belt. Here are a couple of pics.
Just need to gut the old wiring and wire it up now.
Chris
Chris
