NWMO 901 SOS
Good evening all,
I am finally getting around to my 12 volt conversion on the 971 (currently 6V). From following past threads it seems I need the following pieces and parts:
- 37 amp, 3 wire alternator from NAPA $45 + $10 (core charge)
- new 12 volt battery
- step down resistor for coil or a new 12 volt coil
- new termianl block (currently no terminal block present)
- preferably new battery cables (old ones are automotive)
- misc. washers, spacers, etc. to make it fit and line up right
Thanks to John I have a wonderful wiring diagram. I do have a couple of questions.
1) The salesman at NAPA said the step down resistor would not protect 6V headlights adequately. I had previously looked into wiring in series, but with the one arm bandit on, I only have one 6V light to wire. Easiest to replace with 12 V headlight, but I hate fixing something that isn't broke. Comments?
2) It seems the NAPA alternator is going to come with a pulley set up for something smaller than a 1/2" belt that I need. Will the pulley off the stock generator typically transfer?
3) NAPA doesn't have a replacement terminal block per se. They do have some fuse blocks (set up for pop in bus fuses) that looked like they would work fine as a termianl block. Just don't put the fuse in and get the type with screws on each end. Any luck finding a more typical terminal block somewhere else?
4) Lastly, I have some 12 guage wire on hand, but I expect I should have something heavier for the power line from the alternator, 8 guage? Will the 12 guage work for the other lines?
Any comments appreciated, thanks for the help.
Chris
Chris
