Lynn Patrick
Does anyone know where I can get data (HP, bore & stroke, etc.) on a 192 industrial engine? I have been searching & can find nothing!
Thanks,
Lynn
no manual with me.. but looking at the 134 and 172 engines bore/stroke they are
134 3.44 / 3.6
172 3.9 / 3.6
that is a volume of a cyl, times 4 cyl.
using the same stroke of 3.6, I come upwith about a bore diamater of 4.12 with a small margin of error similar tot he calce on the 134/172, using 3.14 as the value of pi.
gotta be close if the stroke is the same.
soundguy
ð = 3.14 for my quick calc purposes
It is my understanding that the 192 is simply a sleeved 172 with the sleeves removed and 4.13 pistons/rings installed. Everything else inside is the same and swaps.
4.130 is correct. stroke is the same.
Production pistons are available in .030 and .040 overbore. The .030 overs are hard to find, eiter cast of forged. I have the sealed power numbers if you need them
