Kevin Little
My tractor seems to be running lean. "Popping" under load and stuttering would be my best description. The original setup had a collapsed air pipe, so a quick trip to the muffler shop and voila! one problem fixed. I see a bolt on the bottom of the bowl, a fat screw tilting toward the front of the tractor and a smaller screw tilting out towards the right. I have an original I&T manual and it gives the starting settings for the idle screw and the main jet, but no pic or description of which is which. Anyone tell me which is which before I start an Appalachian-American tradition and use the trial and error method?
TIA
Kevin
TIA
Kevin
