G'day
Having bit of a problem with the hydraulics on my TE20. The lever on the right to raise and lower the hydraulics springs back up and wont stay down.
When there is no implement connected (it's usually a slasher/mower) the arms raise and cant be lowered. I drained the oil and the arms dropped. I connected the slasher while the arm were down, filled it back up with oil and the arms stayed down but will not raise. The PTO engages and the slasher works fine it just wont lift
When I drained the oil from the bolt on the front right side of the transmission there was a pop and the oil squirted out. Not sure if it's suppose to do that. Note I was also draining the oil from the main bolt at the bottom of the transmission and the left rear side bolt.
Any help would be appreciated. Thanks in advance.
Cheers
Monty
Cheers
Monty
