Difficult Fergie 35
Scott
08-04-2000 00:04:36
The Story So Far.
I hope somebody can help me with this.
My father finally decided it was time to up grade our Fergie TE-A-20 to something with a front end loader. After weeks of looking in the paper we finally found something suitable. We went and had a look at it. It was a petrol Massey Ferguson 35.
It was running a bit rough and needed new tyres but we bought it any way. We got it home and bought new points, HT leads, and spark plugs. We changed them and still she was missing. I decided that the valve cleareances must be wrong so the next morning I took the valve cover off and found something i did not want to find. There had obviously been no oil getting through the the rocker arm and rust had set in so I cleaned it up as best I could and actually got her running pretty nice.
The other day I was out doing some chain harrowing and I ran out of petrol so i poured some petrol out of my boat tank into the tractor, unfornuatley the gas had salt water in it and the tractor started missing. I managed to limp her back to the shed where i flushed out all the lines and poured new petrol in. I started her up and still the constant miss. I shut her off and didn't start her up again until the next morning.
She fired up quickly and i pulled the choke fully open and walked away to get something. I heard the tractor die and just figured that the pertrol must be too rich and she stalled, i turned the key and she wouldn't start she gave just gave the occasional poof then died. I couldn't be bothered mucking around with it so I gave the local mechanic a call.
He came down and couldn't get it to star he took the carb away and reconditioned it. Still no start. We then compression tested it and found the compressions to be extremly low. We concluded that the head gasket must be leaking so i pulled the head off. I lapped the valves in and repaired a leaking frost plug. Today i put it all back togeather with a new head gasket. Crossing my fingers i turned the key and still no start just the occasional poof. I pulled the spark plugs out and there is plenty of petrol over them and there seems to be enough spark. I have just about had enough of this tractor and am thinking of selling it for scrap if I can't get it going soon. The thing i can't get is that it was running fine one day and wouldn't start the next.
Any help would be much appreciated as I am totally out of ideas and am getting pretty feed up.
Thank you
Scott
Dave R
08-07-2000 11:10:07
 Re: Difficult Fergie 35 in reply to Scott, 08-04-2000 00:04:36
I know how frustrating this kind of thing can
be. There are so many potential causes for your
problem. The first thing I would do is have the
head checked out to make sure it isn't warped.
Next re-check compression..poor compression will
definately cause missing. Once you have eliminated these possibilities, you can focus
on troubleshooting fuel or ignition problems.
Have you checked the points to see if they
are burnt or covered with carbon? Also it is
sometimes necessary to re-time the ignition after
replaceing points...oh yeah how about a new condenser. Or maybe the salt you refered to has
broken up some bits of corrosion wich is clogging
the fuel system somewhere. The list goes on and
on. I think you are at the point that you need
to consider if you can afford to step back and take your time troubleshooting. If you rush
you will likely introduce variables that will
make troubleshooting even harder.
let us know if you find the problem
Good luck
Rick Ferguson
09-14-2000 05:51:11
 Re: Re: Difficult Fergie 35 in reply to Dave R, 08-07-2000 11:10:07
this may sound silly but have you double-checked the firing order?? I had the same stupid problem although I didn't change head gaskets etc..was cleaning plugs...working one minute the next spittin' and sputterin' hope this helps. don't give up!
