Engine block for ferguson to 30
Chris
04-02-2003 19:35:02
I am trying to find an engine block for a ferguson to 30 tractor or information on how to repair a cracked block. Have not been able to find any blocks for sale on the the web or any related sites that have any information on where to find a block. Any information would be greatly appreciated.
klf
04-03-2003 19:23:35
 Re: Engine block for ferguson to 30 in reply to Chris, 04-02-2003 19:35:02
I have a Z129 block. It is a core, but it isn't cracked or welded
steve19438
04-03-2003 16:57:20
where ya from?
Paul in NM
04-03-2003 05:39:10
Chris, depending upon where you live, the following sources may be helpful. They either repair blocks or exchange refurbished blocks:
Barnett Head & Block
101 E. 6th St.
Caruthersville, MO 63830-1605
(573) 333-5211
Cast Iron Repair Specialists
Mike Bray
8223 S. 30th S. E.
Everett, WA 98205
(425) 742-4723 Wally Golonka
517 W. Bannerman Ave.
Redgranite, WI 54970-9735
(920) 566-4405
Mac Tractor Parts
Johnny Lindgren
Rt. 4, Box 107-1
Colcord, OK 74338
1-800-882-4742
James, UK
04-03-2003 01:11:10
Plasma welding will do it beautifully - but its expensive.
Depending where on the block the crack is, you can stress relieve the crack (to stop it spreading further) by drilling a 3mm hole at each end of the crack. Then I have heard of people angle grinding the crack to clean it thoroughly and filling with JB weld. Never tried it though.
Apparently this approach does a good job on frost cracks.
If the crack is between the bores, e.g. from lack of maintenance and overheating, then plasma welding is the way to go.
You MIGHT get away with some very skilled MIG or TIG welding, but the heat stresses using those welding processes would worry me.
I'm sure that someone in the US posted on here a few weeks back saying they had a load of Ferguson engine blocks . . . . . but as it was advertising it may have been removed. A search in the archives may help.
Rusty
04-03-2003 14:14:00
 Re: Re: Engine block for ferguson to 30 in reply to James, UK, 04-03-2003 01:11:10
I remember that post. The number is: 573-333-5211
