Ferguson -still- not charging
Anders - master
01-26-2003 14:31:36
Hello, I'm back here, a month after my last cry for help. Due to looooow temperature followed by a period of rain here in Sweden I have had to leave the Ferguson TE that won't charge sitting in the field where it broke down. Today I have spent hours on trying to get it charging again. No success I am afraid. At least I now know a bit more about how this electrical system is built. Here's the situation: I have a good battery charged to slightly more than 12V. As the engine starts this drops to just below 12V. I started by disconnecting the big wire from the generator while the engine was running and tested the smaller wire. the reading was around 4V. After this I checked all the wires from the regulator and they all seemed to be in correct positions. Now, I guess here's where the real troubleshooting starts: I removed the regulator and forced the contacts together. The red light on the dashboard shut down and the voltage meter read 13.2 V. I suppose this proves that the generator works. As soon as I let go of the contacts they opened again and caused a new red light on the dashboard. I did this a couple of times and after I while of turning the engine on and off the regulator seemed to become more and more reliable closing the contacts without my aid. I tried mounting the regulator on to the tractor twice before I gave up - as soon as it was in its correct position it failed again. I thought of a friend who is dealing with old carparts. I went to him and bought an ancient regulator "New in box". This is a German made Wehrle regulator but it has fitting instructions for Lucas as well. I installed it and Imback where I started. The Ferguson ain't charging. Now I wonder. As I measure the contacts on the regulator: What should my readings be? When I check "BATT" or A (connected to the starting switch) I have full power there. For the other two terminals - they are both out of power. The only other place where I can see that at least parts of the charging system is working is that annoying red lamp. Any ideas folks? Help would be highly appreciated.
Anders - master of wires
02-09-2003 09:10:47
 Re: Ferguson -still- not charging in reply to Anders - master of jump starting, 01-26-2003 14:31:36
Gentlemen: The day has come when I can rely on my Ferguson. After having replaced the regulator, inspected the generator and done everything I thought was possible I decided to replace the all wires that had anything to do with the charging system. I was so lucky to see that the red light blacked out as the engine started. The generator charges somewhere around 13 volts now. Not much, I know, but it seems to be sufficient for my Ferguson. Now I just have to tape the wires to each other to make the wiring look okay at the same time as it works okay. I guess I can't blame ferguson for poor quality. Having to replace the wires after 50 years is acceptable. THANK YOU SO MUCH everybody helping me with good ideas when I was starting to think this tractor was impossible to get back in working order. I will let the tractor start to work next week. There is a car wreck and some junk I need to bring to the city dump. Without the Ferguson I wouldn't be able to do this. Cheers from Sweden / Anders
02-08-2003 16:02:03
Today I have gone over the charging system again with no luck. Everything seem to be in order and still that red light stays on... I have disassembled the generator and it looks very good. I have tested ohms and short circuits. I happened to find a rare book my uncle gave me years ago: The 1937-47 Chevrolet workshop manual in Swedish. Even if Chevrolet and Ferguson have nothing in common this book is a great source when trying to solve the mystery of the missing electricity. Right now I have the generator put back together but not mounted on the tractor. I'll put it back on and try a simple trick I learned from the Chevy manual. With the motor running and generator turning along, quickly short circuit the big terminal on the generator. If there is a rather big flash the problem should not be the generator. Sounds like a method invented by Fred Flintstone but it seems like a method worth trying to me.
Spence
02-05-2003 18:59:34
I did the conversion to 12V for my MH30 using the diagram supplied in the YTMAG Archives and it worked perfectly.
So I'd suggest you get an s10 alternator and switch to that. There is also a diagram and write up on generators in the Archive also that may help you.
jeff
02-05-2003 16:31:07
i also have been having trouble keeping a charge on my tractor, i recently took the starter switch off and noticed there was no insulation causing a short i'm putting new starter switch on, was told this could be the problem of tractor not holding charge.
Gordon
02-02-2003 21:26:42
There are 2 charging systems A and B Try your old reg. again. Hook A on gen to A or arm on reg and F on gen to F or field on reg. and bat wire on. Now Ground reg.to tractor.The points that are together with the spring. If you make that spring tighter it will charge more.Be careful sparks can fly and do not over charge that will wreck the gen reg and batt.Check the battary posts that they are clean and good ground.
mac
01-31-2003 13:00:36
I think the problem that you are having is that the generator and the voltage reg. are not synchronized to charge together. Try taking a screwdriver and grounging the hot wire off the generator to the case of the generator with the tractor engine running. This might take a few try,s but if the generator is working, it will boost the output. Whenever you change eather the generator or voltage reg. this has to be done. Let me know if you have success. Good luck. MAC
Jim W
02-01-2003 19:25:16
 Re: Re: Ferguson -still- not charging in reply to mac, 01-31-2003 13:00:36
Mac, You are describing a short circuit from the output of the generator to ground. I think rather than fix the problem this will cause fireworks, just like if you connected the battery terminals together.
If you get a good connection with your screwdriver, there is a good risk of burning out the windings of the generator. Personally I would be afraid to try this but am open to hearing how it is supposed to work.
Jim W.
Phil (VA)
01-27-2003 08:17:58
At approx. 1200 rpm I expect to get at least 14 volts at the battery when my 12 volt charging systems are working properly. I don't think 13.2 is enough. I like the advice of taking both the generator (or alternator) and VR to an electrical repair shop and have them check them out together.
01-27-2003 09:05:06
 Re: Re: Ferguson -still- not charging in reply to Phil (VA), 01-27-2003 08:17:58
Taking the stuff to a workshop would be an easy and safe thing to do. Still it would feel better to make it work properly by doing it myself... You know - male pride. Besides that, I know the electrical workshop in my area all too well. If I'd bring the generator there I am quite sure they'd ask me to pay for a hundred hors of labour and a hundred new parts. I did go there once in the past and I have talked to others that went there... To me it seems like this electrical system should be as complicated as one of those old fashioned bicycle generators. If you connect a lightbulb to positive and ground it it lights up and you know everything is okay. Am I wrong? Surely there must be a way of measuring the output from the generator an easy way. I have opened alternaors in the past and succeded in bringing them back alive. Being more old fashioned I suspect a generator should be easier to get working than an alternator. Or was the alternator a techincal improvement that was both more reliable and easy to work on?
Phil (VA)
01-27-2003 10:59:55
 Re: Re: Re: Ferguson -still- not charging in reply to Anders - master of jump starting, 01-27-2003 09:05:06
The alternator is a tech improvement in the sense that it will charge when it needs to do so even at lower RPMs. The generator requires higer RPMs to charge properly. Sorry your local shop is not reliable. There is a guy named Dell on the Ford N Board who is very knowledgable about these charging systems and may be able to help you further. You might go over there and search for him and send him an email.
Jim W
01-26-2003 17:17:54
By your description I am not so sure your generator is working. Where do you measure your 13.2 volts?
The contacts of the regulator are supposed to open when the output of the generator falls below about 13 volts, so the battery doesn't drain through the generator, and When this happens the light goes on.
Did you try opening and closing the contacts as you describe at different engine speeds? If so, did they close more easily at higher speeds?
Maybe the field winding has gone open. It's supposed to be 6.2 ohms (assuming you have the Lucas C39/2 generator). That 4 volts seems high to me, but only by intuition.
When you say the other terminals show no power - one (D for dynamo) is supposed to be connected to the output terminal on the generator, and the other (F for field) connects to the smaller field terminal on the generator. Something is definitely wrong with that picture, since you say you see 4 volts at the field terminal.
Here is a bit of text from the service manual:
"The function of the regulator is as follows:
1. Breaks the circuit between the battery and the dynamo if the dynamo voltage falls below the battery voltage. This prevents discharge of the battery through the dynamo when the tractor is stopped or idling.
2. Controls the maximum voltage reached by the dynamo.
3. Controls the maximum current output of the dynamo.
".....if the voltage or amperage reaches a predetermined limit, the regulator breaks the circuit to the field and cuts in a resistance. This immediately cuts down the voltage and amperage until the contact points close when the output rises until the circuit is again broken by opening contact points. These cycles occur so rapidly that the points vibrate at a high frequency and thus hold the output at a constant predetermined maximum.
"The voltage regulator is thus permitted automatically to to cope with electrical loads as applied, and maintains the battery at full charge without overcharging."
There is also a bunch of stuff about temperature compensation - to summarize: when it's cold the voltage to charge the battery is higher.
So I think the generator is faulty. If you have an auto electrical shop somewhere around, or even an older regular repair shop, they may have a rig to test it. If it were me at this point I would take the generator in and get it checked out.
Regards,
Jim W in coooold Ontario Canada.
Anders - Master of jumpstarting
01-27-2003 06:40:20
 Re: Re: Ferguson -still- not charging in reply to Jim W, 01-26-2003 17:17:54
>By your description I am not so sure your >generator is working. Where do you measure your >13.2 volts?
After having read your answer I am not sure either. I measured the 13.2 on the battery.
>The contacts of the regulator are supposed to >open when the output of the generator falls >below about 13 volts
This COULD explain the whole situation. If the generator is producing just slightly more than 13 Volts this won't be enough to close the regulator contacts. When I force them to close they sometimes stay closed but most of the times open up again after a few seconds. Perhaps the generator is not "dead" but producing electricity just below the limit that the regulator requires.
>Did you try opening and closing the contacts as >you describe at different engine speeds? If so, >did they close more easily at higher speeds?
I closed them at the same engine speed each time.
>Maybe the field winding has gone open. It's >supposed to be 6.2 ohms (assuming you have the >Lucas C39/2 generator).
Can I measure this without opening the generator?
>That 4 volts seems high to me, but only by >intuition.
Perhaps I wasn't carful when measuring. I'll do an other test and read the instrument more carefully.
Hmmm, I wonder if I have mixed up the contacts on the generator. I might have measured on the small contact. There are no letters on the generator. The smaller one is located half an inch ór so higher than the bigger one. The higher should then be "F", right? >Here is a bit of text from the service manual:
Interesting, thanks!
>These cycles occur so rapidly that the points >vibrate at a high frequency and thus hold the >output at a constant predetermined maximum.
The text above was what made me think the generator might be "almost okay". When I force it to start charging it does so. Sometimes it continous for a while and sometimes it stops charging almost instantly. When I force the contacts together the generator might be producing 13.19 volts or so... I see no vibrating of the contacts. They are either on or off.
I wonder: If the generator is good enough to charge 13 volts but no more it can't be that bad can it? Would an inside cleaning help? Could this be caused by worn carbon brushes?
I suppose that is a good idea, but still I would like to see if there is a way to check the generator properly. Could I perhaps connect a flashlight battery to one termainal on the generator to get it started and then use a voltage meter on the other one to see what comes out.
One thing more: Polarising: When I mounted the new regulator it said in the instruction that I sould connect D and F until >I saw a spark. I did this on the regulator. Should I have done it on the Generator instead or doesn't it matter?
Kevin: A Chevy generator would probably be a good solution. There are two reasons why I won't do it that way. 1. In Sweden Chevys are quite rare and that goes for Chevy generators too, so if I'd replace the whole system I would probably use an alternator. (I have one from an old Plymouth Valiant). 2 Even if my Ferguson looks really sad at the moment I still want to keep it as close to what it looked like 50 years ago as possible. One day it Will get new paint and better tyres!
Tomorrow I will quit work rather early. Hopefully I will be spending the evening with the tractor.
Cheers
Anders
Jim W
02-01-2003 07:56:06
 Re: Re: Re: Ferguson -still- not charging in reply to Anders - Master of jumpstarting, 01-27-2003 06:40:20
....Perhaps the generator is not "dead" but producing electricity just below the limit that the regulator requires.
>>If there is more than one coil making up the field, it is possible that one has gone open and the generator is not operating at full capacity, but this is pure speculation on my part.
>>Maybe...I think so...try measuring from the field terminal to ground. >When you say the other terminals show no power -
>>Yes. It just takes a bit to energize the field, so it doesn't need such a heavy wire. When the battery has been quite discharged such as when you've run the starter for a while, the generator needs to source quite a bit of current to recharge, hence the heavier wire from its output terminal. >These cycles occur so rapidly that the points >vibrate at a high frequency and thus hold the >output at a constant predetermined maximum.
>>I doubt it really, but it certainly won't hurt to clean it up, and if you're going so far as to disassemble, new brushes now will save you doing this again in a decade or two. Don't sand the copper on the armature where it makes contact with the brushes; that is too aggressive; it is better to use an eraser.
A common problem is worn bearings, so it would be worth checking those too while you're in there.
>>I am not sure what you mean here but I think you can do most testing by measuring the various things we've discussed so far with the generator in situ.
>>It should have been on the generator. The idea is that the field coil(s) are an electro-magnet, which is why they need to be energized. They retain some residual magnetism after the tractor stops running though, and this residual magnetism is of some polarity depnding on whether your system is positive or negative ground. Once the generator starts turning the magnetic field of the field coil(s) builds up in the direction of the residual magnetism. "Polarizing the field" is done especially when changing from positive to negative ground. A wire from the the battery (non-ground) terminal is touched briefly (a few seconds only) to the field terminal in order to ensure that the field's residual magnetism is of the correct polarity. From then on it will charge properly. Sometimes if a generator has been sitting around non-operational for 20 or 30 years the residual magnetism in the field is so low that it also needs to be "polarized".
JIm
kevin
01-26-2003 21:26:11
I don't want to sound like a jerk but unless its a concours restoration, why not just put a one wire chevy alternator on it? Dead simple, reliable as an anvil and kits are available.
