Compression Help
Rusty
12-31-2002 11:03:49
Just rebuilt a TE-20 and the compression is 30 pounds on all 4 cylinders. Same compression with oil added to the cylinder. Anybody have this problem before?
Norm in Ont.
12-31-2002 14:53:24
 Re: Compression Help in reply to Rusty, 12-31-2002 11:03:49
Hi Rusty, At first glance, sounds like a valve issue, as you should get 120 + psi. Are you sure the cam is installed correctly? You should email Big Dean for a more thorough diagnosis.
Good Luck
Norm
glen
12-31-2002 12:48:25
other than the low compresion reading how is it running ?
Rusty
12-31-2002 13:39:27
 Re: Re: Compression Help in reply to glen, 12-31-2002 12:48:25
Haven't got the electrical installed yet. Adjusted the valves and now have 70 pounds on all cylinders. Should it be around 120 pounds?
James, UK
01-01-2003 06:39:40
 Re: Re: Re: Compression Help in reply to Rusty, 12-31-2002 13:39:27
Happy New Year Rusty (and all others)
I rebuilt my TE20-85 a while back, and also had the head completely redone - springs, valves, self-lubricating guides, inserts, skimmed, the lot - but did the valve lapping into the head myself.
I thought I'd done a pretty good job (why is it that we engineers always convince ourselves we've done well???) and could still start the old girl on the handle. She ran on four instead of two, didn't overheat or die when hot, and all in all I was pleased.
After a few months of road use, topping, and a bit of ploughing, the starter switch failed - so I thought I'd start it on the handle. HA HA!
Was there some compression there or what! My guess is the valves had settled in nicely after a bit of running in and were now gas tight.
Long story, but bottom line is don't panic yet, run the engine for a while, then check for compression again. Even hand lapped valves and inserts aren't smooth by a long shot, so they won't seal too well at first.
James, UK
