FE 35 or MF 35 tractor identification
Jon
12-14-2002 07:39:45
I recently recieved either a Ferguson FE35 or a MF 35 tractor , any help on identification would be greatly appreciated , It has the Standard Motors LTD 23C Diesel, the hood assmbly and hood ornament are Ferguson , the only things on it that would even relate to MF, are a MF sticker on the seat (obviously not original) and the MF model 32 loader installed on it . The radiator was made in Coventry, the engine came equipped with both glow plugs and a intake manifold heater of some sort , it has the 3 spd + reverse transmission, I am slowly removing the 20 coats of paint on the hood assembly to expose the original color , and the original lettering is under it as well, so far the only thing ledgible is " diesel" It also has a Delco Remy starter and generator, but has an AC of england Air cleaner assembly . any thoughts as to what it might be ??? obviuosly if the dash plate was present i would not be asking for your advice . thanks
Jon
Jack in NB
12-14-2002 10:50:35
 Re: FE 35 or MF 35 tractor identification in reply to Jon, 12-14-2002 07:39:45
Hello Jon -
It's a pretty good bet you have a TO-35. My 1960 parts book shows the 23C as availably in the TO series, and the Delco electrics indicate US manufacture. The FE's had Lucas and CAV electrics.
The glow plugs were fitted after serial no. 188 851. As the head was different for them, it was probably original; the thermostart in the intake manifold was probably added later to help starting. (The best starting assist is a block heater or a heater in the lower rad hose.)
The serial number would be S(tandard chassis) D(Diesel, Standard Motors 23C) and F if you have a single stage clutch or M if it's a two stage, with a number after 188 050.
They switched to Perkins I think in 1959, but there must have been some overlap in numbers and production because I have a 35 SNM 177 934 with a Perkins. I think it's a 1980.
The N in the second place indicates a Perkins diesel engine.
The Standard is a very long-lasting engine - about 35 hp, smooth running, about 35 hp compared to the Perkins 38. I had a Standard with over 5000 hours and the crank was still standard size.
Lots of parts still available, and more help on the Massey discussion site here (in the grey bar at the top of the page).
Hope this helps.
Jack Wetmore in Fredericton NB Can.
Jon
12-15-2002 15:19:04
 Re: Re: FE 35 or MF 35 tractor identification in reply to Jack in NB, 12-14-2002 10:50:35
Jack ,
your right about the block heater some one already added one to the tractor, I slowly removed all the layers of paint and found foil type decals that read "FERGUSON 35 DIESEL" with foil type Ferguson system decals at the rear corners of the hood by the dash, I am guessing you are right about it being a TO35 as it was silvery gray on the cast parts , and Red on the tin parts, thanks for all your help- Jon
