TE-A 20 CONTROL LEVER ADJUSTMENT
My 3 pt hitch does not drop until lever about 4" from the top. I have read that it is supposed to start to drop at 2.5". To correct this I am to move the quadrant assembly forward or rearward. Does anyone know which way I should move it to have the lever start dropping the hitch at 2.5"?
Thanks in advance
I can tell you there is no fluid up at the top so you can loosen and adjust it as you need and not loose any
fluid.
