Farmall H Lower pedestal bushing
Hi all. Would like to know the clearance between the lower pedestal bushing and the steering spindle on a Farmall H narrow front end tractor. Also is this bushing made entirely of steel, hardened or not hardened? Thanks in advance.
There's a large brass bushing AND ball thrust bearing at the bottom of the bolster shaft.
There's typically about 1/4 of vertical play and NO horizontal play whatsoever in the pivot shaft.
Greater vertical play suggests the ball thrust bearing has failed.
