Trying to get my dad's old H running, 6V. Started with battery & cleaning pts. Started up a few times then nothing, would not turn over. Took off the starter to look at the ring gear teeth, looked OK to me. Had starter rebuild. Guy said drive shaft was bent, usually happens when you get to many amps not enough volts. Decided to replace the cables as they weren't in the best shape (corrosion/damaged) along with starter push button. Cables were originally 2 gauge I went with 2/0 was this a mistake? I noticed when they came in all the cables were black which indicates to me negative but they all had + symbols on them. Does that really matter. Tractor is positive ground, neg to starter switch and switch to starter. Anyways started up fine again half dozen times and now nothing, will not turn over. Advise?
