Case 530 Backhoe but not CK
IaRoadKill
New User
I have purchased what I believe is a pre-1960 530 CK.
Sadly, I can find no serial number on the tractor it s self just the backhoe and bucket.
The reason I believe it is pre-1960 is that the decal says only 530 and the backhoe has two exposed hydraulic cylinders.
This brochure is the only picture I have found on the Internet that correctly matches my equipment.
I am looking for operators manuals and repair manuals.
Any help is appreciated.
If it has an alternator it will be negative ground, if it has a generator it could be either, that era machine was usually positive ground, but it was fading out then, nearly everything this side of the sixties was negative ground, it was common practise to polarize the generator back then for what ever way the battery was grounded.
AJ
It's usually easiest to identify based on the loader and backhoe models rather than the tractor. Is it round nose or two headlights? Shuttle? I'd guess you have a w-3, they were very common. I have a round nose, mine is technically a 58 320
