comparison of the kubota 2019 bx23s 1957 CASE 320 INDU
ejensen
wanted to know comparison of the digging power, lifting brush onto a burn pile, my case has homemade fixed thumg
(quoted from post at 15:48:20 10/07/23) wanted to know comparison of the digging power, lifting brush onto a burn pile, my case has homemade fixed thumg
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto164327.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto164328.jpg>
Apples and oranges in my opinion, not really in the same class to compare. Your 320 is a full size unit and the BX23S is a Sub-compact unit. Here are spec sheets from the manufacturers so you can compare the areas you are interested in.
Case 320 spec sheet link.
https://assets.cnhindustrial.com/ca...s/cce_LB_Historic_320_brochure_06-26-2009.pdf
Kubota BX23S spec sheet link.
https://www.kubotausa.com/docs/defa...detailed-specifications.pdf?sfvrsn=aed3617e_4
HI jim,
Thanks for the comparison for the two backhoes. Mine is old but in good shape. I agree it is hard to compare the two machines. The Kubota looks like a
riding lawnmower with a bucket and backhoe attachment.
Chrias
