Blade lift cylinder
a49deere
Just purchased a 1958 420c, I know I am the third owner. The ram that lifts blade is the type with pins, like used on implements, to limit travel, like on a plow. Does this seem like the correct cylinder? thanks
First owner had it for 11 yrs. Second owner has owned it up to last week!
It might be correct, it might not. It can make a difference on what blade is on it. Unless you know the blade manufacturer and model, pictures will be required of the whole set up, as a number of different blades could be on it and not all were John Deere blades.
