Ford 655d engineering issue?
dannyidp
I'm very curious if there was an engineering issue with the steering cylinder on the 655d? I know they only had that cylinder for a couple of years and it seems no matter how you run the hydraulic hoses with the flex of the front axle it either gets into the PTO shaft the fan or the pulley. It seems almost impossible to put a hydraulic hose on without it hitting something. Any suggestions fixes on the single double acting cylinder?
