goldhunter_2
New User
OK i BOUGHT A 1976 CASE 450 CRAWLER Dozer for my son to use on property , it has been running very dependably until recently he called said after running a while if you stop and let set still if will not move again , shut down 15-20 minutes later start and move.
I drove up here to help him we changed all filters , the suction screen I did find gear teeth but dozer still moves fine like before so not sure if that is previous problem already fixed and just didn't clean screen???? again start dozer it moves fine climb straight up on 12x12 blocks no problem but park for a few minutes while we talk and it will not move???? I'd think if trans hyd pump on side of motor was bad it would not move at all and that is what baffles me.
What else do I check next?
any help would be appreciated
