old and crazy
New User
I had posted awhile back about the hydraulics had just stopped working one day lost breaks lift and everything, and then starting working again. But were slow and weak checked pressure going to the main hydraulic pump showing around 110 pounds of pressure could not increase it with shims. So I put and new primary pump on put new seals in and new hoses and changed all the filters as well. Now it has around 125 pounds of pressure going to the main hydraulic pump. When it first starts hydraulics are pretty good but within minutes it starts moving slow and the hydraulic oil fills with what looks like millions of air bubbles. And the primary pump was checked out by a hydraulic shop it was fine. Thanks in advance for any advice
