Morning all! Merry Christmas,
I finally got the little guy running again. I now have a hydraulic question.
In the left side of TD340 is the hydro pump. On the outside of that cast housing is where the hydro pressure line is located. Bolted to the housing is another housing to which a hydro hose is mounted to that feeds the hydraulic distro box. Between this housing and the pump housing there should be something that seals that area. It is either an O-ring or a flat ring. See the pictures to understand what I am referencing. Where can I get this ring. I have no ring, it most likely fell off during the first disassembly.
