sparkiefarmer
My crawler will push like a champ in 1st gear, but immediately slips in 2nd or 3rd and struggles to get moving in 4th. By slip i mean, you will hear the motor start to work, then if stops sending power to the tracks and the load comes off the engine. It does keep some tension on the drive as if you pull it into neural it will roll back usually. It is also tricky to shift, have to be quick or it gets stuck in neutral and you have to shut it off. It will not spin the tracks in anything but 1st. It has very wide tracks on it and 9200 hours on the clock. I have only had it for 100 hours. previous owner overhauled the undercarriage. I changed the oil and filters when i got it, I put Agco Permatran oil in it.
What could be going on and where do I start on diagnosing this?
