Company Logo (800) 853-2651 Shop Now
case 580 cab heater
Martin Seebach
01-28-2023 10:35:48
Hi, Had a cab heater hose split from rubbing on frame. Living near San Jose, CA the cab heater has not been used in the 16 years we've had it. (Wiring and heat exchanger rotted and looks scary) I'm thinking of shutting down the input hose using largish butterfly screw valve above the outlet port where in exits engine. This should deal with the leak. Any drawbacks come to mind or issues that may come up in the cooling system? Thanks for your thoughts.
Jim.ME
01-28-2023 10:42:23
 Re: case 580 cab heater in reply to Martin Seebach, 01-28-2023 10:35:48
Return hose must be shutoff or plugged as well. There should be no issues with shutting/plugging it off as the heaters were added on options.
