brushfire16
New User
This message is a reply to an archived post by lee little on January 14, 2015 at 20:09:24.
The original subject was Case 411.
I have a 1950s case 411 with a 4cyl 4.1l gas engine and a while back I slipped a bearing does anyone have a replacement number for a rod cap bearing on this particular machine?
if it slipped a rod bearing id sure look deeper.cam bearing feeds crankshaft to the rifle drilled holes in crankshaft via mainbearings that feed rod bearings. you possibly have 3 problems . thats my nickles worth ,im probably wrong but every spun rod bearing ive encountered had deeper troubles
