Company Logo (800) 853-2651 Shop Now
vac manifold nuts
kenbob
12-19-2022 05:37:19
To update a previous post: I got my brass nuts off my manifold bolts with our rounding or ruining any. I took a cap off a spray paint can and filled the outside ring with PB Blaster. I stuck the studs head down in it and left it set a few days. The PB made the brass look semi-new again. I also found it probably wasn't necessary. As someone said in a previous post, the brass nuts were so they wouldn't weld to the studs. The reason the studs turn out is because corrosion at the end of the studs keeps the nut from backing out. I found they would turn in easy enough so I turned in, oiled, turn out, turn in, oil etc. Most everybody who has done way more engine work than me probably knows this, but I post for the few who don't.
Tgrasher
12-19-2022 06:30:38
 Re: vac manifold nuts in reply to kenbob, 12-19-2022 05:37:19
Good tip. I've made it a practice of cleaning bolts with small wire wheel brushes and a cordless drill. It doesn't take much crud to bind up a nut.
