Company Logo (800) 853-2651 Shop Now
vac stuff
kenbob
12-15-2022 06:48:00
doing a valve job on my 51 vac new style. The manifod studs turned out with the brass nuts frozen.I don't understand the brass thing. Do I need to seperate them. Were they intended to lock on, since they seem to not have lock washers? Also I am not happy with how close the muffler is to the hood. I thought of putting a short extension so the muffler would be a little higher but 1-15/16 size seems impossible to find. Open to any ideas on mufflers.
Ronald in NWMO
12-16-2022 15:07:43
 Re: vac stuff in reply to kenbob, 12-15-2022 06:48:00
Here is a VAC with what I believe is a glass pack muffler????? Was on the tractor when I bought it 15 years ago. It works fine. I dont know what kind of muffler is on my other VAC but its not case and is much bigger, maybe a little more quiet but not much.
Third Party Image
Third Party Image
Ronald in NWMO
12-16-2022 07:40:26
Third Party Image
Third Party Image
kenbob
12-16-2022 08:00:15
 Re: vac stuff in reply to Ronald in NWMO, 12-16-2022 07:40:26
I switched my 351 from upflow to down when I found the down header with exhaust pipe and glass pack attached. It seemed much quieter than the larger upflow muffler, but some of that is because the noise was coming out the pipe behind and below me instead of in front of me. But even standing away from the tractor it seemed quieter. There is probably a reason why most of those tractor mufflers are less than $40. Maybe not much muffling going on.
r.w.b.
12-16-2022 02:17:53
remember as you muffle more than engineers design you increase heat on valves when under load.
also glass pack mufflers are heavier than oem design ,so manifolt and elbow breakage rises. i
i thought ihc mufflers for c farmals were too big n hit hood on vac cases. do what you want its yours just me 2 cents worth
kenbob
12-16-2022 06:24:58
 Re: vac stuff in reply to r.w.b., 12-16-2022 02:17:53
I was thinking about putting an extension as I don't like that muffler so close to the hood. The weight is a valid point. If that thing breaks off new parts are to be had, but the nuts on the old one are firmly welded. The IH muffler is 1 lb heavier. It is 1 wider so 1/2 toward the hood, but if it were elevated a couple inches it would work out I think. Yes, glass packs are heavier I think.
oldproudvet
12-15-2022 09:01:41
A lot of folks use brass nuts on ex manifolds because they will not corrode to the studs. Perhaps you have brass plated nuts, which do exist, and they will corrode to the studs. You're lucky they came apart that way, and I'd just reuse them. As far as lock washers are concerned they're a no-no on exhaust manifolds, heat makes them worthless and many times they break into pieces and your nut is now loose. My 2 bits. Larry
kenbob
12-15-2022 14:12:16
 Re: vac stuff in reply to oldproudvet, 12-15-2022 09:01:41
Larry, I always thought it was as you said, but when I looked at fleabay all the used brass nuts were being sold with the studs attached, so I thought maybe I had it wrong. I am not the only one who finds them stuck on the studs I guess.
Don Rudolph
12-15-2022 08:26:00
We had the same problem on a 430 hood. The local muffler shop made us a custom extension for about 7 dollars.
kenbob
12-15-2022 14:10:34
 Re: vac stuff in reply to Don Rudolph, 12-15-2022 08:26:00
I will push the envelope further. Has anyone used a non-stock muffler on a vac? I know it has to be skinny. Some glass packs are pretty narrow. Wondering if they would be a lot louder than the standard, as their doesn't seem to be much sound deadening to it.
Don Rudolph
12-15-2022 18:08:44
 Re: vac stuff in reply to kenbob, 12-15-2022 14:10:34
We got our VAC muffler from Fleet Farm in the IH section.
AJB-830
12-15-2022 19:01:26
 Re: vac stuff in reply to Don Rudolph, 12-15-2022 18:08:44
I also have an IH muffler on my 1946 VAC. But I purchased the one with original IH specification for an A, B, or Farmall C that was designed from original IH drawings by Ken Updike. These look the same as the IH Stanley mufflers you get at Fleet-Farm, but they are really quiet. They fit the VAC with no modification. You might have to get them from an IH dealer or from a company that sell antique tractor parts. Al
kenbob
12-15-2022 20:05:12
 Re: vac stuff in reply to AJB-830, 12-15-2022 19:01:26
My brother has a 1650 Oliver with a Farmall muffler on it, so it will go into the shed. It is kinda weird. It almost sounds like a Farmall when it runs, even though it is a 6 cylinder
kenbob
12-15-2022 20:03:48
Thanks, I am all about quiet these days. I also have a ford 2000 3cyl gas. That thing is LOUD! No way around that except to replumb for a downflow muffler. Even then the engine is still loud.
