1955 Case CC carb questions
Tom in Mo.
This tractor hasn't run in over ten years. I finally got good spark out of the magneto and now need to work on the carb. I removed the carb because it was spewing gas from all the seams.
I cannot find a name on the carb. There is a small round tag attached with the number 7124D on it.
Is this a Zenith carburator? And does anyone know where to get the proper rebuild kit with gaskets? Thanks
Here's a picture of it.
If you are looking for parts for a 1955 Case CC there is a reason you can't find anything, Case didn't make the CC in 1955, its probably a 1935 model. The DC replaced the CC in 1939.
Contact John Saeli for parts, if he doesn't have them he can probably tell you where you might find them.
http://www.external_link.com/
Jim
Leaking gas at the gasket means the needle valve is not working properly. Maybe the main thing it needs is to free up the needle valve.
I already split the carb and the float is cracked and a little squashed like it had ice in it (?) don't know what did that but it will need replacing too. If I can't locate a kit, I'll take the time to make a new gasket and do a total cleanout and try to make it work. Ron is this a Zenith?
Again, DC was made in 1944, CC production was 1929-1939. If you can find the serial number on the tractor we can help you with model year and that will help identify the carburator type.
Jim
It's a 1937 model; for 6 digit serial numbers you use the first and 4th digits and subtract 3.
40 minus 3 equals 1937.
Floats for this carburetor are very hard to find; it is a Zenith 124 1/2.
tractor ser.# isn't going to tell you jack, several cc's have dc carbs installed so the only thing that means anything is the carb. tag number, Tom is on the right path
