Spotted Horse
Hooked up the 1175 to my post hole auger and started making post holes. Had to drill in a weedy area, auger got a bunch of weeds stuck in the bit and the auger quit going down.
Raised the auger up and shut the tractor off,... got off the tractor cleaned the weeds off the bit,... got back on the tractor,... hit the ignition switch,.... and "NUTHIN" happened.
Cleaned the ground cable real good, turned the switch on,... amp needle jumps to 12.5,... continue turning the key to the "start" position and "NUTHIN",... but the needle falls back to the left of the amp gauge with the key still in the "on" position.
Got my test light and put it on the "hot" cable (up by the starter), cleaned the ground cable some more, and noticed that whenever I turn the key to "start" the amp needle falls back to the left side of the amp gauge, the "hot" cable going to the starter is NOT "hot".
Wait about 10 seconds with the key still sitting in the "on" position, and the amp needle jumps back up to 12.5 and the test light comes back on.
Do you fellas think my ignition switch is bad, or the starter selanoid? (it has always started great before)
Thanks
Spotted Horse
Thanks
Spotted Horse
