mikefromiowa
The last time I mowed with my VAC, I noticed that my amp gauge was jumping madly back and forth. also, it would sometimes show about an amp of discharge as if it isn't charging. I would then go back to charging. Seems to start acting up after it has warmed up for about 1/2 hour or so. It is all stock with a newer amp gauge, and light switch with resistor for cut out. Would a bad cut out cause the jumping amp gauge or is my generator giving up the ghost? I'm thinking not. I've noticed that when I put the new light switch the amp gauge was showing a charge of about 18 amps. if I run the lights, it shows about 8 amp charge. Seems that the low charge and high charge is little difference. I'm assuming that I probably need to adjust my 3rd brush.
any help would be great. thanks.
