(quoted from post at 12:10:18 01/25/23) Did WD's come from the factory with a ground cable or the flat ground strap?
Flat braided ground strap that went down the backside of the battery box and was covered up by the instrument panel when it is slid into place, Be sure the instrument panel ground screw is clean and tight to the battery box or the generator won't charge.
I found a good selection at a local farm supply store(B----Gr's)that was reasonable. Trying to go 6 volt on my WD and wondering all the flat style cables are capable of handle the 6 volt starting current? It will be the first time in 60 years it is correctly done!!
Most are converting 6 to 12v to get more reliable starting and brighter LED lights plus be common with other vehicles and chargers.
