WD spark plugs
I run NGK3112 in my WD45 and have had very good luck with them so they should be fine in your WD
After the last 50 or 60 years, who knows. From the factory, 3/8" reach spark plugs were used on all WD45's and early D-17's prior to chassis s/n 24001. Any D-17 after that and all 170-175's were always 3/4" reach plugs. HOWEVER, if you replaced a tall cylinder head with a new one from A-C, you were given the newest head, which meant 3/4" reach plugs. So, one must look over the depth of the threads if there's a question.
