Company Logo (800) 853-2651 Shop Now
Looking for a 230 buda diesel engine or somthing equivla
gtank101
01-19-2023 14:44:56
I have a old road grader that has some cracks in the head and block runs but smokes like a chimney any help would be appreciated thank you in advance.
gtank101
02-14-2023 07:54:34
 Re: Looking for a 230 buda diesel engine or somthing equivla in reply to gtank101, 01-19-2023 14:44:56
do You have a number i can call u on?
gtank101
01-30-2023 14:04:17
Do you Have a phone number i can call you on ?
gtank101
01-23-2023 12:30:45
Do you have a phone number?
gtank101
01-20-2023 10:03:52
some are on the head and some are in the cylinder /sleeves all the way through to the next cylender
Tramway Guy
01-20-2023 18:54:57
 Re: Looking for a 230 buda diesel engine or somthing equivla in reply to gtank101, 01-20-2023 10:03:52
Cracks in a prechamber design head is not unusual. Unless they go to the valve seat, or leak under pressure test, they are probably harmless.
And cracks between sleeves at the top of the block is also common. The head gasket seals it. But if there are cracks down at the bottom of the block (in the area of the o-rings), the block is toast.
Tramway Guy
01-19-2023 19:23:41
Cracks may not necessarily be fatal!
Where are they located?
DrAllis
01-19-2023 15:38:01
Well, they used the first generation (1953) BD-230 in the WD45 tractor. The second generation (1960) would have been in the model A-2 Gleaner combine. I've never seen an A-2 with one, but I know that's what they had...very few were built diesel powered.
BonaparteSouth
01-20-2023 06:04:06
 Re: Looking for a 230 buda diesel engine or somthing equivla in reply to DrAllis, 01-19-2023 15:38:01
the A-2 motor has a RoosaMaster injection pump on it. I have a complete power unit off an A-2 D in my storage shed of motors, earmarked for a wd45d project.
